Subwoofer cutting off and restarting at high volumes
  • 5
Could be a few things,
Could be a loose connection from the amp to the subs,
Could be a loose connection on the amps +/-/R
Could be that the impedance goes to low at certain freqs and sets the amp into protect.
Check all of your connections.
I noticed that also when the amp cut off the sub that the overhead light also cuts off. And then comes back on when the amp does. Could I be drawing too much power from my stock battery or something? The battery doesn't drain quick if the car isn't on or anything just cuts off a few electrical components.
From my experience, it sounds like your amp is going into protect mode. Likely from lack of electrical support, and poorly set gains.
most likely this, it was happening with my set up about 2 weeks back and when i went to look things over the nut that holds down the line fuse on one of the power lines to the amp had shaken loose. tightened it up and has never happened since.
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
804
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
LOL. Ya man. Its been busy. Im off today, but got stuff to do around the Casa.Be a Great sub man, and very nice amplifier. If you can swing a few...
18
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
kylej
kylej
Franklin, West Virginia, United States
xxxbasshead
