Subwoofer And Amp Setup
michaelking
Does this sound like it will match up correctly. And will I be able to heard quite a ways away.
(AMP)
http://www.crutchfield.com/p_236TC8001/M...
(SUB)
http://www.crutchfield.com/p_2067DCVR12/...
or
should I buy this amp. I noticed that it's been discontinued, so I'm not really sure if I would recieve any sort of repair, etc.
http://www.sonicelectronix.com/item_6595...
Also on the sub I see only one set of speaker outputs that are rated at 2 ohms. The mono amp has two speaker connections (Speaker 1 And Speaker 2), so how would I hook this up? Would I just connect the negative lead from the sub to the amps - input on speaker 1 and the positive lead coming from the sub to the amps + input on speaker 2.
(This is a photo of the amp speaker connections)
http://www.crutchfield.com/App/Product/I...
One more question. Do you guys think I will be fine running the sub amp and another 80 watt x 4 channel amp (Profile AP1040) off of 8 gauge wire? I have a 4 gauge coming from the battery that connects to a dist block and splits off into two 8 gauge wires. I will also replace the 100 amp ANL fuse with a 200 AMP ANL Fuse (Located on power wire).
I'm also sorta afraid to run my amp at 2 ohms.
michaelking
michaelking
Lexington, Ky
michaelking
NorthFramingham
    Jun 30, 2026
