Subwoofer & Amp help ! -----------new topic !
the pioneer with a 400rms mono amp NOT BOSS, PLANET AUDIO, HIFONICS,.. maybe jbl 500, heck even the power acoustic 2300 tested at 600rms 2ohm (it's same amp as ppi i650) if the pioneer is 4 ohm it would still get 400 watts which is fine they $83 or so.. look at this dyno and check his other videos even the $59 dual is better than a boss that only does 100 watts, no boss!!!
Ok I’ll take the advise from all of you I’m skipping the boss amp and I’ll get a 1300 watt power Acoustik amp
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F201178485300
That’s the link to one I found on eBay >.> can you confirm this is the best bang for buck amp? Or better than the boss ?
It says it’s 2 channel amp but I’m only using one sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Update found a 1 channel amp on wallmart check this link & uh 3 ppl on the reveiw said it tested below what they advertise......so I’m confused now one side saying it’s good one saying it’s bad
https://www.walmart.com/ip/Power-Acoustik-RZ1-2300D-2-300-Watt-1-Channel-Amplifier/20604535
Check out the price doe pretty low
Ok I’ll take the advise from all of you I’m skipping the boss amp and I’ll get a 1300 watt power Acoustik amp https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F201178485300
don't get the 2 channel if it's a/b amp could be tad cleaner but then u can only bridge it to a svc4 ohm sub.. with the other amp u could run 2 of those subs or 1 4 ohm dvc sub wired at 2 ohms and u can just turn gain down if alt can't power it well or is sub can't tke the 600rms.. which brings me to what u said it says 2300 on it it tested at 600 i told u that, it's same amp as ppi 650 which is good (they just lie and over rated it).. also clas d mono amps **** less power than ab amps (which is what most 2 channels are) so a 300 watt 2 chan could **** as much power as a 500 watt mono.. get a mono amp u have more option, less current draw. only get these cheap amps that have been tested so u know what u are getting idk anything about any of the other models just the one bigblank tested.. watch his dynos
if u can go up a little get this jbl500 (which is what i recommended 1st) it test close to 800 watts at 2 ohm but if u get a 4ohm svc sub it'll do 460rms and just set gain low and it won't draw that much power but u have a nice amp.. look around maybe u can get a discount on walmart or a sale on ebay sometimes https://www.amazon.com/JBL-GTX500-watt-Subwoofer-Amplifier/dp/B00YQ674D0
Aaaahh I don’t understand lol im really new at this so I have like no idea what ohms / svc4 or mono means etc. I checked out the jbl and ermm I don’t wana spend 106$ for a 80$ sub might as well get a amp/ sub combo for 200$ at that point so I’m gonna stick with the wallmart onces I spent you but I think you said don’t get the 2 channel one but get the other one ?
Yeah ....... it’s over 100$ Just looked up “Pioneer 8601 “ also I want new not pre owned
Sorry, it's $112. I will tell you from many years of experience, you will end up buying equipment again and again if you go cheap. It's going to cost you a lot more in the long run. The guys on here know what they are talking about and anything recommended, for the most part, is going to last you. If it were me, I would be patient and put a few more dollars with the $100 and get something the first time that will last.
look on cl and fb in your area see if u find mono amp in your price range and then tell us what it is.. i've seen kenwood amps $30.. also u will need to match the ohm load so if u get a sub that says d4 or 2ohm final load u must have a mono amp, if u get one that says wired to 4 ohm load u can get a small 2 channel.. this is y i said get a mono amp that can do 2 or 1 ohm because u can add a 2nd sub later or u can buy 1 d4 wired at 2 ohm and get more power to sub but it would also work with 4ohm svc sub.. this is 1 of the reasons we power subs with mono amps..
OK ! So uh craigslist wise near me i found a kenwood amp thats 10$ and its a kac-8105D 1000W max 400 watts at 4 oms . Its only like 11$ and it retails for 180$ sooo either im gonna get scammed cause it doesn't work and i cant test it nor can he show me or ill get lucky...... which is the reason why i dont like CL but ill try it since its close 20 mins away. Anywho ok ill up my budget just link me an amp that will do the pioneer good its only a 10 inch sub doe so i dont think we need much power...... ive already confirmed im not getting the ****** boss amp soooo yeeee what u got for around 100$ that will do the job. checked out some of the posted ones from the other memebers of the community and not sure if i wana pull the trigger since like they only have 1 reveiws or they were said to be **** in the reveiws.
would a 11$ kac-805D work with my pioneeer?
Were the ones I linked too far or are you just looking for Kenwood
too far its on the other side of the city would be a 1hour or 2 hour drive
and the 114 kenwood amp guy just left me on read when i asked if it worked ..... lol im gonna take that as it doesn.t
***update once again im not buying from CL too many stupid people or scammers
person didnt respond after i asked where he got it or if it worked ...lol i got a "maybe"
Ali2627
Ali2627
Los Angeles,ca
shredder2
