subs to amp
bopo668
JerryRig
Ok so dont flame i have a crunch pzi 1500.1 it was real cheap and i have a 15" type r and i have the sub wired to 2 ohms i just dont know where to put the + - wires that come from the sub in to the amp there are two + - terminals on my mono amp what ones do i plug them in
Don't worry about flamin', enjoy what you got. Look up the amp manufacturer on-line for wire diagrams. If not possible, try the negative from one amp output and the positive of the other amp output. This is assuming the sub has a dual voice coil for 2ohm application and the amp can comply with that.
If the sub is a dual 2 you can wire to 1 or 4 ohms
If the sub is a dual 4 you can wire to 2 or 8 ohms
If the amp is a mono (single channel) amp and it has 2 places to connect speaker wire, just pick one positive for positive wire and one negative for negative wire,
the amp is bridged parallel internally so to speak
the extra + and - is just for ease of hooking up more than one subwoofer.
Did that help at all?
bopo668
JerryRig
bopo668
tex
bopo668
