DToon
Alright so I have a Massive Audio p1000.1 Mono block With two 10'' Massive audio RW 400w RMS DVC 4Ohm subs hooked up, wired down to 1Ohm. For a while everything was fine, but now whenever my deck is on(Sony Xplod gtx130) my subs will continuously make an off beat popping/scratching noise and its not just when the deck turns on but even when im playing music itll start to do that. When the subs start to do this ALL the lights in my car begin to flicker as if my car is going to die. And for the first time yesterday i saw smoke coming from my amp so i shut everything off. The Fuse by my battery isnt blown and the amp doesnt have a fuse to it. If it matters my car is an 05 Dodge neon. My gain is not even halfway, my LPF is at 110~120, Subsonic is on and around 30, Bass boost is at 0. My deck settings for HPF and LPF are both off as well as mids, highs and lows all at 0. The ground is sanded down to the chassis. Today i had the gain at maybe 1/4 of the way and everything was fine until i got home, turned the gain up back to where it normally was(below 1/2) and it did it again, and i continued to watch my sub movement as the popping happened and the popping was causing one to stick out and they just didnt move like they normally would. like the left one would stick out and the right one wouldnt. I dont know how to really explain it but they just weren't on the same beat if that makes sense. I dont know really know where to start since im still kinda new in the car audio world. I'm also going to pick up a DMM today, even though i should've had one from the start. Sorry that its a lot lol.
