Subs Popping
ok i fixed my grounds, 0awg from battery to chassis, 4awg to amp. tried running it at 2 ohm still doing the same thing. I took the amp out and put in a friends car and it played fine. The only other thing it could be is the head unit right?
You should be using the same gauge for your grounds as your power. If you have 4 gauge power, use 4 gauge grounds.
Kef
you can allways have a bigger ground then power... the same size dosnt matter as long as its as big or bigger, i have 1/0 grounds because i plan on upgrading and dont feel like rerunning shit later=)
did you run your new rca along a power cable? also i would say sounds like you have a lose rca, id check the back of the hu.
autosportsunltd
autosportsunltd
Clarksburg WV
autosportsunltd
