If it weren't for the incredibly poor reliability record of the Xplod line, it would actually be a pretty competitive line of head units ...
As for the Alpine problem, simply turn your gains up until you hear distortion, then back them off a bit ... It's because the sub out on the new Alpines reach peak output higher on the volume scale, so at the level most people run their head units (20-24 volume), the output is down in the 1.5-2 volt range instead of the 4 volt range, even with the sub level set to +15 (0 dB). So you basically need to turn your gain up to 1.5-2 volts ...
