subs and box
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1357537453
Features:
Retail Price $299 Each!
120 oz. Double Stacked Strontium Magnets
Power Handling: 600 watts R.M.S.
Frequency Response: 23Hz - 500Hz
Efficiency: 91.1 dB
PHAT 2 Inch Foam Surround
Non- Pressed, Non-Transfer Paper Cone
KM3 Coated for Virtually No Cone Distortion
2.5 Inch 4-Layer ASV Voice Coil
Dual 4 Ohm
2 Ohm or 8 Ohm Operation
Depth: 5 Inch
Hole: 9 1/4 Inch
Diameter: 10 7/8 Inch
126.00 total for 2 of them with shipping.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1359199183
BP-1200.1
* 1200 watts RMS x 1 at 2 ohms
* 14-13/16"L x 10-13/16"W x 2-11/16"H.
BP1200.1
Die-cast chassis uses the entire footprint for amplifier cooling
Direct-Connect" allows choice of 4 - 8-gauge power and ground cable
High-frequency switching power supply is more efficient, drawing far less current from the vehicle's electrical system
Four high-level and low-level inputs facilitate constant bass, regardless of head unit fader position
Variable electronic crossover and bass-boost optimize subwoofer performance
Specifications
Suggested Retail Price:
$749.95
Output 4 Ohms:
600W x 1
Output 2 Ohms:
1200W x 1
Signal to Noise (dBA):
>100
Frequency Response (± 3dB):
20Hz - 500Hz
Total Harmonic Distortion:
0.1%
Input Sensitivity:
250mV - 4V
279.95 with shipping
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=1357915710
Specifications:
* Built with 3/4" MDF material
* TWO - 10" holes for speakers
* Dimensions: 12" height x 12.5" bottom depth x 9.25" top depth x 30.5 width
* Divided chambers for better sound
* Two connection terminals
* .77 Cubic Feet per chamber
50.00 with shipping
With this set up you looking around:
455.95 And you will be pushing over 600 watts rms so amp will be great, and the subs can take 600 rms , and even more. they are not joke. But I was just showing what i thought. You can still go audiobahn their are cheaper than that. You can always go with the natural sound, and lower jbl amps...
Seeya
Welcome to online purchasing //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif . I love it, atleast untill someone ropes my credit card info and charges on it. Then I'm going to hang myself.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
not sure yet all my gear in my car now is alpine but alpine sub and amp would prolly be out of my range money wise now all that gear u guys suggested sounds sweet but might also be out of my range so i might save up for a while till i can afford it unless there is a cheaper suggestion around 500:(
i am also guessing u are talking in american dollars im an aussie so it would have to be under $500 aus
and also right no i have 6x9's in the back shelf would u suggest taking them out and puting in 6" or just leaving it?
Could you please tell the american to austrailia currency trade. you know, like does 1 american dolloar equal like 1.20 over there or what.
Plus that will effect shipping cuz alot of people on ebay charge more for forgein orders...
cheers mate the 6x9's are alreay in straight into the back shelf i got a new one made up 4 it was thinking bout just geting an pretty good amp 4 da moment and run my splits and 6x9's of that 4 a bit better sound and save 4 a sub sound better as an idea that way i get good gear but wait a bit longer insted of ok gear right now
john_1984
john_1984
Perth, Western Australia
john_1984
