subs & amps
iwishinew
i'am curious to know what would happen if i wired 2 dual 4 ohm subs up to a 2 channel 800 watt amp bridged ,and then wired a single 4 ohm sub up to one of the other channel on the amp. iam i allright with the 2 subs or wired up to the amp or am i committing suicide on my amp with the single sub.
To be honest, if you amp is bridged then you should not have anymore channels on a 2 ch. amp. When you bridge it you combine the left and right channels together to form 1.
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
iwishinew
iwishinew
henderson, nc
Jasontb2000
Doxquzme
    Jun 15, 2024
Doxquzme
    Jun 15, 2024
