BringDaBoom
I kinda have the feeling the answer/s will be a "it depends", so if it is please explain.
You have Sub A and Sub B. Both are of the same type (I.E. SPL, SQ, SQL, etc), and will be powered by the same amplifier providing the same ammount of power to each.
Sub A is a 10"
Sub B is a 12"
Each is in a sealed box built to the specs of the sub.
Question 1.) The 12" should displace more air, thus having more SPL, correct? Logic would say yes, no?
Question 2, the real question depending on the answer to 1.) : If you have a specifc model sub (be it a 10", 12", 15") that is said to displace the same ammount of air as two specific model smaller subs, then given the oppourtunity to place that larger sub in it's optimum enclosure (For the sake of argument, let's say sealed), it shoud match the SPL of the two smaller ones (put in their optimum enclosure also sealed), provided they are fed the same power, correct?
Sub A is a 10"
Sub B is a 12"
