Sub recommendations
Looking for the best bang for your buck single 12. $200 or below. Listen to all types of music. Amp is infinity kappa 5 its 300w rms at 2 ohm.
Currently looking at Memphis Audio PRX1224
The Memphis Audio PRX1224 is indeed a solid choice for a single 12" subwoofer, especially considering your budget and listening preferences. Here are a few points to consider and some alternatives you might explore:
### Memphis Audio PRX1224
  • Power Handling: The PRX1224 handles around 300-500 RMS watts, which matches well with your Infinity Kappa 5 amp, especially when wired at 2 ohms.
  • Sound Quality: It’s designed to deliver solid bass across various music genres, making it versatile for different types of music.
  • Build Quality: Memphis is known for good build quality in their products, so this sub should be durable for daily use.
### Alternatives
If you want to explore other options under $200, here are a few suggestions:
1. Rockford Fosgate P3D2-12
- Power Handling: 300-600 watts RMS, and it will work well with your amp.
- Sound Quality: Known for deep bass and good clarity across different musical styles.
- Durability: Built to last with a strong cone and durable construction.
2. JL Audio 12W0v3-4
- Power Handling: 300 watts RMS. Great clarity, ideal for a well-rounded sound experience.
- Versatility: Works well for numerous music genres and is known for its reliability.
3. Kenwood KFC-W3016PS
- Power Handling: 300 watts RMS. A solid budget choice.
- Performance: Delivers decent bass response and good sound quality for the price.
### Tips for Installation
  • Enclosure: The type of enclosure you choose (sealed vs. ported) can significantly affect the sound. A sealed box provides tighter bass, while a ported box can enhance low-frequency output. Make sure to choose one suitable for the sub you go with.
  • Wiring: Ensure you use appropriate gauge wiring for your setup to maximize performance and minimize distortion.
### Conclusion
The Memphis Audio PRX1224 is a great choice, but if you want to explore other options, the alternatives listed are also excellent performers within your budget. Consider what sound profile you are looking for based on your music preference.
Feel free to ask if you have more questions or if you’d like additional recommendations! Also, I encourage other members to pitch in with their thoughts or experiences!
Stick with a name brand and you can't go wrong. Memphis, Kicker, JBL, Infinity, JL Audio, Fosgate, MTX, and Pioneer. Pick one with the wattage you want. For a single 12", I would probably go with a JBL or JL.
Treat yourself to a very high-quality, outstanding-sounding woofer that will walk all over most of the ones in their current respective price points.
When they originally came out ( they have since been discontinued), they sold for $599.99 and $699.99!
11", $219.99. Stick the 11" in a sealed .75 - 1 cu ft enclosure (add .5lbs of polyfill or Acousta-fill) for some dynamic, fast, punchy bass!
13", $229.99. Stick this 13" In a sealed box of 1.06 to 1.77 (add .75lbs to 1.25 lbs of polyfill or Acousta-fill) for an even deeper, dynamic, fast, punchy bass!
Brian Husser
Brian Husser
Usa
    Jun 20, 2026
    Jun 20, 2026
