sub question w7 vs uber
i'll be glad to go into more detail...
look at the specs of the tantrum - the amount of amps it pulls then compare that to the jl 1000.1 per ohm load...
the jl puts out the same wattage while the tantrum changes
look at what this guy wants to put these 2 amps on a 13w7 which has a dual 1.5 ohm load meaning it must be ran at 3ohms but in more detail look at the tantrum's rms at the 3ohm load
finally I suggest looking at the powersupply
clearly the tantrum is a good amp however its not good enough to push a 13w7
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
The tantrum does the same wattage from 2-4 ohms. Which is 1400+ (very competitive or even higher than the 1000.1)
The # of amps it pulls or the powersupply doesn't change the fact that the Tantrum does 1400+ watts. Are you saying that it does way less than that @ 3 ohms or are you saying that the 1000.1 just puts out more power period?
13.5's are dual 1.5
That has already been stated //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
x2, the tantrum has the ability to push the w7 just as hard as the 1000/1
As for which is more efficent, I dunno.
2 more post til 5k //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif//content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
the tantrum will put out more power then the 1000/1, and it has a regulated power supply like the jl, and is almost just as effiecient, because of its class "T" circuitry. Which would mean that when putting out the amount of power then JL can, the tantrum would be just as efficient as the JL, in its amperage. So basically tantrum>1000/1
IIRC the 1000.1 is 1kw from 2-4ohm
Tantrum is 1200+ from 2-4ohm. Most bench in the 1400 range.
Not really enough to tell a major difference in power, but both are rock solid amps and both will get the job done well.
As far as what sub to pick...both have respected SQ and output. I would rather pay the $350-$450 for one of Josh's limited run Ubers. They work well in a small box which is exactly what I would want. I havent liked any of the W7 installs that I have heard in a small sealed box.
IIRC the 1000.1 is 1kw from 2-4ohmTantrum is 1200+ from 2-4ohm. Most bench in the 1400 range.
but the thing is that you can pick up a tantrum for probly half the price of a 1000/1......//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
When and if you can find one. They are not made anymore so you are automatically stuck with used //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
4 used tantrums> 1 brand new jl from deal //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
doh i used 5k //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
there are always some up on ebay.....and nothing wrong wt used.....i got mine used and its fine..........just make sure the seller is respectable.....better then paying 550 (minimum) for the jl....get a tantrum for 300(Maximum)
I have an uber which was for sale, but the guy bailed out so I decided to keep it. The SQ on the thing is absolutely awesome, the most transistant bass I have heard from a sub yet. It is true that it does a great job in a small sealed box, and the higher freq responce is not too bad at all. It is pretty efficient, it gets pretty loud considering how small my box is and that it is probably only getting ~950w.
All and all im real glad I ended up keeping the uber.
I'm gonna have to quote your own signature here..
Though I would suggesting investing in a dictionary
WTF is "transistant bass" //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif That must be some sub to have its own custom adjectives for its bass eh? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
are you trying to say something about its transient response? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
i give up ... you can't reason w/a dumbass
i would have to say the uber is my first choice. i have heard plenty of w7's and i love the sq that comes from my uber. If i had it in a sealed box sq would be even better.
id ont get what this guy is saying.... hes asking what the tantum puts out at 3 ohms..... it puts out 400 watts more then the JL. im not asking which draws more. And im not askign about amps at all. 1000 watts is more then enough for the 13w7. even if its not effiecient and not putting out full power i still think its gonna be putting out more then teh JL.
i went with the uber //content.invisioncic.com/y282845/emoticons/naughty.gif.94359f346c0f1259df8038d60b41863e.gif i hope it works out ok. I just wanna see kids faces when i pop the trunk and its something they never even seen or heard before blowing away w7's. any1 have box plans for something like this. I heard 2-4 cubes ported low low.
mega1268
mega1268
NY
mega1268
