Sub is being picky?
Delusnl
I've been running a TC sounds LMS with a Zapco 750.2 for a couple of months and have not touched anything on the amp or sub since original install and tune. The last couple of days the sub would stop playing at lower volume and if i turned up the volume enough, the sub would kick in.
Now the sub doesnt play at all unless i go back to the box and give it a little tap on the cone (like a motivational push) and then it wil play until i turn the volume down or turn the car off!
I cant figure out the problem, any suggestions?
I would have to pay to ship it there and back!
It stopped playing completely last night //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
No abnormal sounds or anything tho!
Sounds like a lead problem. Sometimes they can be fixed, depending on where the problem is at. Although a lot of the time the repair will just keep failing until you recone it properly.
Delusnl
Delusnl
Nampa, Idaho
Delusnl
