sub help
liljojo4711
how can i see if my sub is still working without hooking it up to my car. i have no wires run and my sub stopped working when i took it out of my other car. the surround came loose from the cone so i reglued it. could this have cause it to stop hitting? can i hook it up in some way to check?
i have a dmm...
A dmm will only tell you if it's impedance is right. If there's a short in it or the tinsels are broke, you won't get a reading.
A ghetto way I sometimes test my speakers to see if they still make noise is to take my chordless electric screwdriver and attach wires from it's battery packs metal sideplates/terminals to the terminals on the sub. If it works it'll make a bass hit. You can only do this though if the batterypack is between 12-15V. Any larger of a battery & you can hurt the sub. You can do the same thing with your car's battery.
liljojo4711
liljojo4711
dallas
liljojo4711
