Sub Help
The way that you are describing these subs, they are single 4ohm.
you can either wire each one at 4ohms, or wire them together for a 2ohm load.
If you wire them together, all you need to do is hook the positive of each sub together and the negative of each sub together before it runs to the amp.
On the first post you said that the subs are DVC which would mean they have 2 sets of terminals, but on the last post you said that they only have one set of terminals each.
If they are dual voice coil subs and are DVC4ohm, this would mean that each sub could be wired at 2ohm or 8ohm each. OR together they could be wired at 1ohm or 4ohm.
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=1
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4
curtis
aaustinikiki
aaustinikiki
Stephens City, VA
Skip01
