Sub Box for 12tw3's
Tamahome23
I have 12tw3 (shallow mounts) that are currently using the factory square shallow box that it shipped with from JL. I have identified a couple of decent under seat boxes for my 2014 Silverado Crew Cab that seem to have good fit for the truck and decent finish.
The uncertainty of my decision lay in the air space for these boxes. The specs I found for the 12tw3's seem to indicate .75cuft is what is optimal for these drivers per side, however the boxes I found come in a .6cuft and a .9cuft build per driver. Both boxes are sealed (which is also recommend for these drivers)
Any advice on which way is best to go and why? Would/Should I looking into PolyFill as well? How much should I expect to use per driver if so?
Thanks for the assist!
Still looking for some feedback on this - and to further convolute my options I've identified a single enclose that will allow my 1.25cuft if I so opted.... Still believe I really prefer to stick with the 2 driver box though.
Tamahome23
Tamahome23
Houston, TX
Tamahome23
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
