Sub based on amp ohms.. 2 ohm or 4 ohm
If my amp runs at 310w RMS 4 ohm and 500w RMS 2 ohm....then should I get the 2 ohm version of the 05 Alpine R? Will be in a 1.75 cubic foot box and want good lows and SQ.
Hawk
Are you asking about single coil or dual coil subs? IIRC, the type r only comes in dual coils.
if your amp is pushing out 500rms x 1 @2ohms. you'll need the 05 dvc 4ohm version model # SWR-1242D CHICK HERE see Option #1
if your amp is pushing out 310rms x 1 @4ohms. you'll need the 04 dvc 2ohm version model # SWR-1221D CHICK HERE see Option #2
Ok now I am confused... the Alpine comes in a 2ohm and 4ohm design... and both are dual coil...
So if my amp runs more power at 2ohms why would I want the 4ohm model?
Because you will have TWO four ohm coils. Check the wiring tutorial on this forum, to learn the different ohm loads and wiring methods.
hawk45
Tool
hawk45
Cincinnati, Ohio
zachzchw
