stupid wiring question.
  • 2
traksta15
I love lamp.
I have an 03 silverado ex cab, and im installing a double din headunit, 2 headrest monitors, 2 amps (sub/comps), my question is, what's the cleanest way to install all this equipment to 1 remote wire so it comes on with my deck? I know I could just run all the wires to behind my deck and hook it up that way but id like to minimize the amount of wires behind it cause theres not very much room and id like a clean install. Thanks in advance!
send the remote wire to one amp, cut a small piece of wire that goes from the input on the amp to the 2nd amp, like a chain? not sure if that would work, but it would use a lot less wire than running a bunch of remotes back to the HU
That's how I have the 2 amps now, I guess I could always daisy the monitors into the amps. Its probably easier to run wires to the amps behind the seat than up through the dash.
Damn can I hire sancho for her so she can buy me a new set of 12" Fi subwoofers?? :D
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
950
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
226
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
637
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
666
traksta15
I love lamp.
traksta15
Mcalester, Ok
traksta15
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
