Stuffing my brahma ???
  • 4
it depends , does the sub need a bigger box. all the polyfill is going to do is make the sub perform as if it were in a bigger box, by slowing down the sound waves. if the sub needs 1.50 cu.ft. box and all you have is a 1.00 cu.ft. box than you need at least 50 pounds of polyfill, because you need a pound per square inch. good luck.
Originally posted by PioneerGlnn it depends , does the sub need a bigger box. all the polyfill is going to do is make the sub perform as if it were in a bigger box, by slowing down the sound waves. if the sub needs 1.50 cu.ft. box and all you have is a 1.00 cu.ft. box than you need at least 50 pounds of polyfill, because you need a pound per square inch. good luck.
It doesn't work in that nature, after a cetain amount of fill the changes are actually reduced.
The correct fill % per cubic foot (not inch) is about 1.5 lbs, anything more is noted to have a degredational effect from there, as noted by Tom Nousaine in the Car Stereo Review mag... Details found here: http://integra.cyberglobe.net/caraudio/resources/fiberfill/
Nice touch on the title...very original //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D Two thumbs up!!!//content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
Thx J , I would like to see 50 lbs of fill in a 1 cuft space !! Isnt that about enough to fill the whole car ! Man walmart would be out of that sh.it for a while !
It was a system from 2 vehicles ago. The enclosure was rock solid. Had a P9 combo to deal with whatever equalization was going to be required.
Can't go wrong with either sub, but the Brahmas seem to have a little more "oomph" down low. Obviously both subs do fine down low, but the...
Spddracer
Sounds Goooooood
Spddracer
Ohio
Spddracer
    May 24, 2024
