How much stuffing should I put in my sealed 1 ft enclosure with a brahma 12" ??? Pack it full , just on the sides ??? alittle of both ???
It doesn't work in that nature, after a cetain amount of fill the changes are actually reduced.Originally posted by PioneerGlnn it depends , does the sub need a bigger box. all the polyfill is going to do is make the sub perform as if it were in a bigger box, by slowing down the sound waves. if the sub needs 1.50 cu.ft. box and all you have is a 1.00 cu.ft. box than you need at least 50 pounds of polyfill, because you need a pound per square inch. good luck.
