straping two amps
  • 6
why strap the amps when you have two subs. Just run each sub off their own amp.
i think its just a guarantee to have the subs play at the same time, same crossed over frequency and power so there will be minimal phase issue. Rather then just guessing if they are at the same settings or not.
basically the load needs to be in series. so if each amp would see a 1 ohm load from a sub, when theyre strapped you want the pair of amps to see 2 ohms
Model SDC2.515
Woofer Size 15"
Fs 33 Hz
Qts 0.643
Qes 0.705
Qms 7.405
Vas 44.340 l
Le mH 3.05
Sensitivity 1W/1m 85.69 dB
Magnet Weight 140 oz
Coil Diameter 2.5"
Useable Throw 2.0"
Xmax 25.4mm
RMS Power 600
Peak Power 1200
Mounting Depth 7.5"
Circle Cutout 14"
Model SDC2.515
here are the specs on the subs and im doing two focal 800.1s
325
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
873
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
No doubt, was just thinking of that when i was mulling getting one of these. https://blackbrickaudio.com/products/100-watt-4-channel-amplifier
990
Hatsfan
Hatsfan
San Antonio, Tx
Side Show
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
