strange problem gettin constant power
95Prober
hi
i have a knukonceptz 0/1 into (2) 4 guage distribution block. i hooked it up correctly and im running the 0/1 guage to my trunk from the engine battery. this block has the digital volt meter display. there is also a 16 guage blue wire that comes from the block itself. originally, i thought it was a remote turn on, but i called the company and they said, ground wire. but whenever i ground the wire to the chassis, the digital display comes on as it should, BUT it stays on all the time, until i pull the wire off the chassis. thats the only way it wont display is if i disconnect that wire. im assuming its not supposed to display all the time when the key is off to. can this be fixed? can a toggle on/off switch be placed in between the block and the chassis ?
95Prober
95Prober
Canada
95Prober
