Stop subs from sliding in the trunk
Make sure you know where your gas tank is if you are going to be be drilling/screwing anything in your trunk!
I bought some velcro but havnt put it in yet
Ratchet strap and a couple1/4" eye bolts!
might be ghetto but i may try the Velcro method under the box
sure velcro holds through car crashes and as an extra measure throw some duct tape up there ***** will never move!
J/K
eye bolts and a ratchet strap cost about 15.00 and takes about 20 minutes to do it right the only tools you need are a drill and 1/4" bit and I believe a 3/8" wrench.
Do L brackets not exist in Germany? I mean how the hell do you guys hold up you shelving?
Im sure they do... problem is I have not the first idea where to get them at.
---------- Post added at 01:38 AM ---------- Previous post was at 01:37 AM ----------
just buy a Bazooka tube..that will solve all u problems...
you couldnt pay me to buy a tube.
Make a false floor out of MDF/Plywood, and screw that joker down..you make it tight enough,and you may not need to screwthe false floor down,just the sub box to it..generally what i do,also gives me something to mount amps/distro blocks/ect.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
Those subsonic frequencies make a difference in how music sounds. Hearing the music and also feeling the subsonics adds a depth to music. You hear...
10
I just learned a couple of days ago that shark fin antennas are powered. Your issue may be related to that. Either the power to the antenna is...
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
It might be "ghetto" by today's standards but I used to run a wire off the battery to a switch then to the amp...back in my youth the Police liked...
15
4K
Heel4lyfe
Heel4lyfe
home
theMessenjah44
