Legit? And need suggestions!
RoYALbLUE08
2008 2009 2010 HONDA ACCORD 2.4L HIGH OUTPUT ALTERNATOR - High Amp Performance Output Alternators for Honda
Anyone ever heard of this company? $296 for a 180 Amo HO alt.
says its a direct fit for my accord.
And also if I'm running around 2300 watts of power. Will I be fine with just upgrading my batteries to one kinetic 1400 and one kinetic 2000 in the trunk?
Right now my system is suffering with only 1200 watts of power. I can hear my sub go low and loud as the voltage keeps changing from 14-12.5 volts
Or should I get the HO ALT and just one kinetic battery? I believe stock alt is 100 amps.
I need suggestions!
That "ho" alt doesn't put out many amps... Depends that might be enough for some vehicles and others will need more. If you set your gains correctly and have those batts the amp should run alright.
[quote name='rebelfromva']My stock is 130. Isn't yours 160 @murph check around op for a better deal[/QUOTE]
on what? An alt? I can't find a better that's the cheapest. I talked to DC before and they wanted like 470 for 200 amps
Get a HO alternator from either DC power, Mike Singer, Mechman, Excessive Amperage, not some random alternator. They will get you solid alternators that put out like 150 amps+ at IDLE, 250+ at high rpm.
As for the battery, I recommend a solid battery upfront like the kinetik
That's what I was planning. Putting the kinetic 1400R in the front and the kinetic 2000 in the back
[quote name='RoYALbLUE08']Without the Ho alt correct?[/QUOTE]
Yeah
Yeah mine is
So you guys think I would be fine with just the 2 kinetic batteries? I don't feel like dealing with changing out the alt
As long as it stays around 14-13.5 I'll be happy. Plus I'm not gonna set the gain up all the way. Maybe like 1500 watts to the subs
RoYALbLUE08
RoYALbLUE08
NYC
RoYALbLUE08
