gnet158
What am I doing wrong? I have a 2002 GMC Sierra and purchased the following to connect my amp to my trucks battery.
Stinger GM battery tap (for the single power cable)
Stinger Pro ring terminal
First I removed the Positive OEM battery tap and replaced it with the Stinger. I then ran the amps power cable into the ring terminal (with plenty of exposed wire), attached it to the battery tap and then tighten everything up. I put the keys in and turn the ignition to its first position, my system turns on and everything seems fine. But when I turn the keys to the next position (to start my truck) I hear a click and everything dies. I am unable to start my truck and nothing turns on.
The only way to get the truck to turn on is to replace everything back to stock. Any ideas?
