Stinger battery or Cap or Nothin?
footeyo86
I had 96 Lumina and had: 3000 watt mono block Boss Blade Amp, 4000 watt Audiobahn Immortal 12" sub, extra battery, isolator in the trunk. Inside the car I had like 5 switches; 1 powering 3 neons,2 fuzz buster,3 vents leds,4 another 8led light,5 cigarette lighter power. The setup looked like this. Meaning I had 2 0awg wires running from under the hood back to the trunk.
All 0 awg wire n with fuses in correct locations
I now have a 98 Lincoln continental; same amp, now a 4000 watt cerwin vega stroker 10" sub, a capacitor and a optima battery under the hood. Still have everything from the Lumina. I want to only add 2 switches with low power consumption. Waiting for warm weather to install.
I dont want to have to run 2 0awg wires through the whole car again. Thats why I bought a cap. I have been reading and seeing everyone says trash the cap.lol.
My question is:
Can the cap serve some purpose? Wanna use it for voltage meter.
Is there a way to install a second battery efficiently without an isolator n such?
I want to use as little trunk space as possible.
Can I get away with just an optima battery under the hood?
Any help is appreciated!! Thank You
footeyo86
footeyo86
St. Paul, MN
btdickey99
