still dont know how to wire!!
It appeared you were asking him to bridge the amp at 2 ohm. Just some misinterpretation on my part I guess.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif:crazy:
thanks for the response guys. after searching, i found a guy who asked the same question: wiring a 4ohm dvc sub to a 4ohm amp and the moderater answered:
Sure you can....wire the VCs in series for 8ohms //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
But seriously, you can wire only one VC, but that's not recommended because it will change everything about the sub. The recommended box sizes will no longer be right, etc etc etc.
So pretty much your options would be to wire the coils in parallel for 2ohm mono (which the amp can't handle), wire them in series for 8ohm mono (which wouldn't give a whole lotta power out of the amp), or buy a 2 channel amp and put one coil on each channel.
so he's saying wire the sub in series for 8ohms. but trigger is tellin me to wire it for 2ohms. im still confused. two guys are saying to wire it 2 different ways for the same result: 150w. which one's right? or am i misunderstanding?
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
My way is just a little more complicated for the same result of using 1 channel of the amp and wiring it to 2ohm(and you would need to buy a rca splitter). Does that help you make a decision?
ohrune
ohrune
san diego
Logikalliquid
michigan born
    May 14, 2026
michigan born
    May 14, 2026
