Bass still playing
Disconnect the RCAs then turn it back on.
Running into another problem so bass was playing fun then all sudden got really bad smelt something that smell like a blown sub but go check the subs and when I push them in they push in just fine. But now rca unplugged from amp and head unit something is still playing just like if a TV went to the black and white thing. I have no idea what this could be. Also turned gain all the way down on the amp and still does that. Idk wtf is happening
If an amplifier goes bad it can sometimes send a high DC voltage to the subs which will fry the coil, even if the amp is smaller than what would normally blow them. If you don’t catch it in time and shut it off and unhook it. And I have had voice coils fry but the cone still moved okay, so that is not always the definitive test. The DMM test is the way to go. It does sound like there could be an issue with the amp as well. Hopefully the subs survived.
A bad smell is never a good sign with electronics.
Im hoping 🙏 if its the amp thats so much better if its the sub I think ill be done with car audio
The subs were super hot to the touch so not a good sign
So you are getting white noise out of the un-signaled sub amp? From what I have observed, you can clip an output by amplifying a low signal. In other words, turning gain higher with too low of a signal. And clipping causes voicecoil odor.
What amp is it?
Good to go in that area then. As suggested, do a visual of the voicecoils. I have old subs that have gotten smelly when played hard without any issues, so it does not necessarily mean they are cooked.
So i measured the impedance from the box and I have it wired to 1 ohm and its reading 1.1? Do I still need to take my subs out of the box if the terminals on the box are reading 1.1?
Mr FaceCaser
CarAudio.com Exclusive
Mr FaceCaser
Charlotte
Mr FaceCaser
