SSD 15" not playing?
How can I check if the ground is correct? Like I said, I've played my components off this amp for over a month without a problem.
Anyways, I went ahead and took out the fuse and took it apart. The middle of the fuse looks fine, but where it's soldered on looks all burnt? Is this normal? Almost like the solder melted like what was posted before.
Replace that fuse right quick and let us know if that helps.
Remember, your remote wire will not show any voltage unless the cd player is turned on.
Hopefully you just toasted the Fuse and it will be a cheap and easy fix
Sweet dude. Just make sure you do not have your gain or bass boost up too high.....that would be causing it to blow a fuse.
But it sounds like it was just a crappy fuse or the solder got knocked loose.
have a good one
curtis
*Ace*
*Ace*
Las Vegas, NV
chardy85
michigan born
    May 14, 2026
michigan born
    May 14, 2026
