SQL Scion tC
Did you see what I did to a scion tC for seals/deadening? The build log is in here also.
Yes I have,, a few times. Im still not sure if I want to bump the 6.5s up to the Mille before I finish the pods. Im not sure how they will sound with the HE tweeters but im guessing good
No, I wasn't referring to the Mille, your speakers are just fine.
I am referring to the work I did in the rear corner and rear quarter. Stupid lossy, that entire rear quarter. We put in a lot of work to eliminate that highly resonant part of the car. Any tC owner should do the same.
That tC is so well sealed, if you try to shut both doors at once, one pops back. It's cool.
We did more than layers on the outside, we did several layers built up on opencell foam. The result is zero exterior flex. Since the interior layer is decoupled from the exterior.
Someone wanting SPL would want something similar, but not foam that flexes. The interior layer should be rigid. I would opt for several layers of fiberglass on top of the foam backing if I wanted SPL.
I like the sound and range of this box but i know this set up has a 50 in it, or at least close to it. I dont think this car likes subs up so Buck is drawing something up with subs and port back with about 18sq inches of port per cube. It may not be as accurate but we will see.
I see what your talking about. I'm going to take your advice on this.
I heard that lol. Got any vids of it with the old box? Did u get a chance to meter it?
No vids
Metered lower then I was looking for. It was a music box and it did that well. I asked for that and I got it so I cant complain. It would really drop though. I had a feeling it would meter good according to the graph but that peak didnt happen in the car.
LosIsATool
LosIsATool
Pensacola, Florida
LosIsATool
