sq amps?
I'm not even going to respond to that. Wow, what was i thinking
To the OP, if you had a kicker sx900.4 and a kicker zx850.4 to run your components, the sx amp has a built in dsp,built in eq, time alignment etc. Thats my point, with the zx amp you'll need external processors to do that, whether it be head unit or whatever.
The DSP is defeatable.
Also the true sq amps aren't cheap either. Yes they don't have crossovers or eq's but that comes at a p rice
You should post a notice: Beware of fake SQ amps that have crossovers and EQ's. Consider it a PSA.
And I can make a Boss, Pyle, or Rockwood into a SQ amp any old day of the week. Because, hey lets just be honest not one person with a car audio system REALLY knows what their amps sound like as they are impossible to listen to. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ya, a class A circuitry amplifier, they're used because of there low noise properties. I have seen some have a total harmonic distortion of around .0008% big difference from the usual .05 of a class A/B and up to 1.% of a class D. A lot is based on install but how can you install an amp that sounds like sh!t to begin with. Polo..
Where are they used? In ice cream trucks?? A true single-ended A class would generate so **** much heat you'd literally need to drive a vehicle with freezer in it to run it. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
You've maybe seen THD stats as such, but you have never heard them...nor will you ever at those levels. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I can easly take a shitty sounding amp and make it sound A LOT better. All I have to do is change my mind. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
pike110
Registered User
pike110
indiana
Keyser Söze
