Rainbow iPaul Amps?
Schuey2002
Despite the goofy name, they don't look that bad. I, uhhhhh, guess.. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
iPaul? Does it come with an iPod?
http://www.rainbow-audio.de/ipaul/
Have you heard anything about these amps, Don? Any word on pricing yet? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
No pricing yet and ETA is around June. Once released Im sure Alot of people will be happy with their prices and features though. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
My German is not very good, but they appear to have internal crossovers? Plus, it looks like you can even bandpass with 'em. Suh-weeeeeet!
I have a feeling that my Memphis amps days are numbered.. LOL!
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Total Harmonic Distortions:
Damping Factor: > 200
Output stage 2 stable, bridge andtri mode capable.
Connector for external fan module
(optional)
Connector for temperature-sense and
display module (optional)
Connector for peak power doubling
Module (optional)
Reversible safety switch-off with thermal monitoring
Safety switch-off with DC current to loudspeakers
Safety switch-off for loudspeaker short-circuit and loudspeaker under impedance
Soft start remote muting for suppression of switch-on peaks
Palladium-plated 25 mm² power and 10 mm² loudspeaker connection
Interference-proof certified by European E-Norm
4 x 90 Watt RMS at 4 Ohm
4 x 140 Watt RMS at 2 Ohm
2 x 270 Watt RMS at 4 Ohm
Frequency Response: 10 Hz – 35 KHz
12 dB High-Pass 15 Hz – 5 kHz
(FRONT)
12 dB High-Pass 15 Hz – 500 Hz
(REAR)
12 dB Low-Pass 50 Hz – 5 kHz (REAR)
12 dB Band-Pass 15 Hz – 5 kHz (REAR)
As soon as you get these in, Don, ya' got to take some pics... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
4 x 90 Watt RMS at 4 Ohm4 x 140 Watt RMS at 2 Ohm
(FRONT)
(REAR)
It would be nice if they had 18 or 24 db crossover slopes..
Of course, you know I will. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
a bit more...
2 x 130 Watt RMS at 4 Ohm
2 x 200 Watt RMS at 2 Ohm
1 x 400 Watt RMS at 4 Ohm
Phase Shifter 0° to 180°
Gain and Phase control via Remote
control with 5m cable
Phase shifter 0° to 180° (REAR)
Gain and Phase control via Remote control
with 5m cable (REAR)
4 Ohm
Output stage 2  stable, bridge and tri-mode capable.
Connector for external fan module (optional)
Connector for peak power doubling module
(optional)
Schuey2002
Schuey2002
USA
troy_audi0
