sq amps?
pike110
Registered User
I know some people will say a watt is a watt, but what are some high quality (sq) amps. focal, zapco, jl???? My next setup I want to be high sq. I am going with a 15 mag and polk sr6500 comps. I've been using rockford power series amps and kind of want to step it up a little. Thanks for any advice.
zapco is great for sq my 4kw does over 4000rms at a 4ohm load........i think one key to having great sq while still being loud is finding an amp that does high watts at 4ohms you could try a zapco 9.0 they do like 2200 at 4ohm mono but zapco stuff is high you get what you pay for right
Zapco's class A's are some of the cleanest now my personal choice is an old school A/D/S multichannel plate, just pure love , lol. Oh by the way a watt is not a watt only in power terms but there is a differnce between a clean and a dirt watt and in different waveforms. Polo. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Polo, you should be over at ecoustics.... I saw over there you were wanting a tc 5400. I ordered a 18" 5400 about a month ago, but they are waiting on parts. I will post pics when it comes in.
"Polo, you should be over at ecoustics.... "
Thats not very nice, lol. What am I to smart to be here or what J/K...Polo //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i love my zapcos. i run a couple reference and reference DC series in different setups, but amp going to replace my DC650.6 and DC1100.1 a 4.0, 2.5, 9.0, and a DSP6 pretty soon.
audison is worth looking into as well.
Zapco Class A's? //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
All things equal, you won't be able to tell a Rockford Power series sound from a Zapco from an Audison from any other amp you buy. The best SQ systems in the world get that way by having the best installers and tuners, not necessarly by spending a lot of money on something that's mostly a figment of the imagination. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ya, a class A circuitry amplifier, they're used because of there low noise properties. I have seen some have a total harmonic distortion of around .0008% big difference from the usual .05 of a class A/B and up to 1.% of a class D. A lot is based on install but how can you install an amp that sounds like sh!t to begin with. Polo..
Im gonna have to disagree.
Much as many people can tell when a passive crossover in a component set is using higher quality caps and air cored inductors, better parts quality inside an amp will also be detectable.
Think you can tell the difference in a Rockford and Zapco? From http://www.autosound2000.com
THE $10,000 AMPLIFIER CHALLENGE RULES {revised May 28 , 2005}
By Richard Clark
There is no question that all amps are not the same. It is very easy to measure large differences in the performance of amplifiers. This is true in nearly every
known specification, including power, noise, distortion, etc. My experience has led me to believe that even though these differences can be easily measured,
hearing those differences may not be so easy. Given the relatively small magnitude of performance differences, there is a giant step between amplifier
performance and our ability to hear performance differences.
It is claimed by designers, manufacturers and especially salespersons that differences in amplifiers are clearly audible. Reasons include "obvious"
advantages of one type of circuit topology over another. For example, it is claimed that certain designs have a smoother midrange response whereas other
amplifiers exhibit tighter bass. Tube fanatics claim that tube amplifiers have that "warm" sound we all need in our systems.
Such descriptive terms are certainly subject to personal interpretation. It is not my intention to determine if one particular amplifier is better than another
amplifier. Differences in the quality of the discrete components and constructions are more appropriate for settling the issue of "good - better - best." The sole
purpose of my amplifier challenge is to determine if the differences in amplifiers are audible.
What differences are Audible?
I believe the perceived differences in amplifiers are all due to various factors that can be explained with basic physics and elementary psycho-acoustics. For
instance, if two amplifiers are not carefully matched in volume, and one amp is slightly louder than the other, then it would be a simple matter to detect such a
difference. In such an example it is important to understand that it is not the circuit topology, quality of the component, design excellence, or superb marketing
and packaging that caused the noticeable difference - it was an error in the test setup! It is my present belief that as long as a modern amplifier is operated
within its linear range (below overload), the differences between amps are inaudible to the human ear.
Comparing Amps
The idea here is for a test subject to scientifically demonstrate his/her ability to hear differences in amplifiers. It is our job to carefully match the amps so
that we are comparing "apples to apples" instead of "oranges to frogs." This means that we sure wouldn't want to compare one amplifier that had + 12 dB of
high frequency boost against another amplifier that was adjusted for + 12 dB of bass boost. Such a test would be easy to pass - even on identical amplifiers
with consecutive serial numbers.
For our comparison test, we aren't concerned with which amplifier sounds best to the test subject. We only require that the listener be able to identify each
amplifier when it is powering the speakers. Since many folks seem to believe that amplifiers have some kind of distinctive sonic character, this test should be
easy to pass. Right? After all, we're talking about comparing those harsh sounding, high distortion, squeaky "widget As" to those warm sounding, smooth, bass
hog "widget Bs."
Now pay particular attention to the following sections. Since we're looking for differences in amplifiers, and we already know that those differences are
probably going to be very, very small, it is important that the parameters under our control be carefully adjusted so as to be equal as possible. This means that
we must be cognizant of differences we might unknowingly introduce between amp A and amp B. They must be adjusted as identical as possible. We already
mentioned the importance of volume. The same goes for the L and R balance. It sure would be easy to choose an amplifier that exhibited left side bias over a
balanced amp. Right?
Well, in order to keep this amplifier comparison test fair, there are a few other parameters that must be considered. I'll list them all in the following section.
Amplifier Comparison Test Conditions
1. Amplifier gain controls - of both channels - are matched to within +- .05 dB.
2. Speaker wires on both amps are properly wired with respect to polarity. (+ and -)
3. That neither amp has signal phase inversion. If so correction will be made in #2 above.
4. That neither amp is loaded beyond its rated impedance.
5. That all amplifiers with signal processors have those features turned off. This includes bass boost circuits, filters, etc. If frequency tailoring circuits cannot
be completely bypassed an equalizer will be inserted in the signal path of one of the amps (only one and the listener can decide which) to compensate for the
difference. Compensation will also be made for input and output loading that affects frequency response. Since we are only listening for differences in the
sonic signature of circuit topology, the addition of an EQ in only one amps signal path should make the test even easier.
6. That neither amp exhibits excessive noise (including RFI).
7. That each amp can be properly driven by the test setup. Not normally a problem but it is theoretically a problem.
8. That the L and R channels are not reversed in one amp.
9. That neither amp has excessive physical noise or other indicators that can be observed by the listener.
10. That neither amp has DC OFFSET that causes audible pops when its output is switched.
11. That the channel separation of all amps in the test is at least 30 dB from 20Hz to 20kHz.
Page 1 of 2ഊIn addition to these requirements the test will be conducted according to the following rules.
Amplifier Test Comparison Rules
1. To make things easy we would prefer to use high quality home type loudspeakers for the test. If our speakers are not acceptable, the listener can provide any
commercially available speaker system as long as it uses dynamic drivers. The actual measured impedance cannot exceed the rated load impedance of the
amplifiers tested. If, however, the tester would like to perform the test in a car, we will use a car, however, it will have to be provided by the test subject. For
practicality we will have to limit the number of amplifier channels to four or less.
2. Amplifiers will be powered from the same power supply at a nominal 14 volts DC. (any voltage is OK as long as it is the same for both amps) see note
3. The test can be conducted at any volume desired; however, the amps will not be allowed to clip. In other words, listening volume can not exceed the power
capacity of the smallest amp of the pair being tested. (power capacity will be defined as clipping or 2%THD 20Hz to 10kHz, whichever is less)
4. No test signals can be used - only commercially available music.
5. The test will be conducted "double blind". The listener will control the switcher and can switch between amps as often and at whatever speed he desires.
The listener can compare the amps for as long as desired. The listener can repeat any sequence as many times as desired. The listener can review his selections
as many times as desired before ending the test. For practical reasons we would like to keep this at least no more than a few hours. A test session will consist
of 12 A/B sequences. Passing the test will require a positive identification of each amp for all 12 sequences. Remember, guessing will get you about 6 out of
12. If the differences are so great, and a subject can really hear the difference, then he/she should be able to do so for all 12 sequences.
6. To win the $10,000.00, the listener must pass two complete sessions of 12 comparisons. Passing the test means 24 correct responses.* The amp of choice
can be compared to the same or a different amp in each session - challengers choice. We have many amplifiers in our demo inventory such as, but not limited
to, Alpine, Rockford, Kicker, Phoenix Gold, Precision Power, MTX, Adcom, Kenwood, Pioneer, Sony, etc. You can pick any of them or bring your own.
7. All amps must be brand name, standard production, linear voltage amplifiers. This does not exclude high current amps. Amps can not be modified and must
meet factory specs. They must be "car audio amplifiers designed to be powered from a car's electrical system." (see note below)
8. Failure of an amp (this includes thermal shutdown) during the test will require that the test be repeated after repair or replacement or cooling of the amp.
This means that the entire test session will have to be repeated.
9. The amps will not be overloaded during the session from either a voltage or current requirement.
10. To save time the listener will have to pass a quick 8 trial session to qualify for the extended 2 session test for the money prize. Any 2 amps can be used for
this test. Passing this qualifying test will require at least 6 out of 8 correct answers.
11. The amplifier power up and/or power down sequence will not be acceptable for comparison. (The turn on/off noises of some amplifiers would give it
away.)
12. Cost to take the test is $200.00. $500.00 for people representing companies. Payable in advance, scheduled appointments only. Done correctly the test
takes several hours and I don’t have the time if you aren’t serious.
* Twelve correct responses in a row is certainly a lot of correct listening but $10,000 is also a lot of money for a few hours of easy listening. The way people
describe the differences is that they are like night and day. I would certainly not have any trouble choosing between an apple and an orange 12 times in a row.
When compared fairly I believe the differences in amps are much too small to audibly detect and certainly too small to pay large sums of extra money for."
"If I am wrong someone should be able to carefully take this test and win my money. Even if I am right, if enough people take the test eventually someone will take
my money due to random chance. This is the reason for the large sample requirement. If you feel that you can easily pass this test but 12 sequences will give
you "listening fatigue" I am willing to modify the requirements. Since the way it is being offered is a challenge and only my money is at risk I am willing to let
a confident challenger "put his money where his ears are.
If we are willing to make this a bet instead of a challenge, I am willing to drop 1 sequence for every
thousand dollars put up by the challenger against my money. This would mean:
____My___________ _ _Your________Trails Required to win__
$10,000 to $0 = 12 Tries
$9,000 to $1,000 = 11 Tries
$8,000 to $2,000 = 10 Tries
$7,000 to $3,000 = 9 Tries
$6,000 to $4,000 = 8 Tries
$5,000 to $5,000 = 7 Tries
$4,000 to $6,000 = 6 Tries
I will not do the test with less than 6 trails. It would be statistically meaningless and reduce the challenge to mere gambling.
NOTE 1----- from conditions 2 & 7 This test mentions 12v and "car" amps only The test originally began with home/studio type amps and was
revised in 1994 for the car audio industry. This version dated 2005 is again expanded to include 120Volt home/studio/commercial type amps"
Front Stage Tweeter Amp:US Amps USA 50X
Front Stage Midrange Amp:US Amps USA 200X
Front Stage Midbass Amp:US Amps USA 200X
So you wasted a lot of money when you could have just bought some Boss amps instead?
pike110
Registered User
pike110
indiana
Keyser Söze
