where do these usually mount on the vehicle? I have a rex and im not sure where to install them. These are the spring loaded poppers that help push the door open when the actuator releases the door.
are you asking where the actual popper is mounted? or the button for the popper? usually the button is mounted underneath the sideskirt or in the wheelwell somewhere...
I installled everything so far the brain the wires I even cut out the metal door panel so i could weld the actuators bracket instead of bolting them up, I dont think itll be that difficult to install. All it is, is drilling 3 holes and mounting it. Im just looking for a place to do that on the rex or a location someone else has installed them.
