SPLBEAST's new box *VID* 2 12BTLs 8k watts
Skip01
Diggy
Well some of u may have seen that other box....lets not even get into that train wreck haha.
This new one is double baffled and fully resined...pretty solid.
Ok...well after a screw up with RE box calc. this box is 3.7cu@48hz
For being tuned so high it really can still hit the lows pretty well..not like his other one but still.
Its painful on the higher stuff...Shoulder Lean is nuts
His setup is in the vid:
http://www.sendspace.com/file/gx1t3k
Should have some TL numbers this weekend...hopefully a decent score.
did you seal the trunk off on that new box off where the seats fold down? (the subs are facing forwards right) if so how what did you use? if not, do you think there are any cancellation problems?
Nooo...not sealed off at the moment but still louder than facing backwards.
Im thinkin the box was too big and was kinda blocking the pressure from gettting forward...this way is a lil louder...and should be a lot louder once we seal it off.
ok sounds like you just confirmed my plans to do the same thing with two audioque hd312's... i think i might try to seal it off using fiberglass.... i plan on building two seperate boxes each 2.5 @ 38 and sliding them in next to eachother. that way i know i wont have a problem getting them in.... im hoping i can hit 150.... but only time will tell
Nice...i dont see why not...Cavy are pretty good on the meter for a trunk car from what we've tested...def. a lot better than my Civic.
Good luck with it and post pics when ya start:)
Skip01
Diggy
Skip01
Marrero,LA
splbeast
