Speakers for rear
williams22
I just purchased some PG RSd65CSs for the front and now I need new rear speakers. The size opening is 5 1/4". Should I get a fairly inexpensive set of components or will that not sound good? So I just go with co-axials? I will probably have about 50-75 w rms to power each of them.
True twistid, but keep in mind if he powers rears off HU, and front off an amp, then the fronts would get loud much faster, and you wouldn't need to turn the HU vol up to a level where the rears would distort.
depends on how you set your gains... ive learned that its better to have maximum listening level at nearly 100% headunit volume to achieve maximum preout voltage ... but everyones different
williams22
williams22
Vermont
mlstrass
