Boston Acoustics Pro60 6.5 tweeter placement
Leave them in the coaxil configuration, and get the Imaging System. It's tweeter frequency range allows you to put the I/S tweeters up higher to pull up the sound stage, without blurring the imaging.
I moved the tweets off the mid and put them in the factory location, about 5'' higher and 3-4'' forward. No real reason, just wanted to fill the stock locations. The dash might be too high though, I dont know for shure, but you can try different areas and find what sounds best. Im curious to find out about this imaging system the previous poster talked about? A little more info would be greatly appreciated. Thanks, Chuck
from what i can tell from the website is that the imaging system is nothing more than 2 extra m2 tweeters and two extra xovers? im assuming xovered the at the same frequencies as well? and how the hell do you wire it up? AGAIN im assuming it comes with a little bridge connector like the pro 60's do to connect the three xovers together or do you need a seperate amp?
http://www.bostonacoustics.com/car/car_product.aspx?category_id=14&family_id=83&product_id=324The driver is nominal 8ohm. It can be switched to either SPL mode (same crossover point as the Pro 60 drivers.) Or, it can be set for imaging mode (crossed over at 8Khz). It is dockable with the Pro 60 passive crossover set, or it can be powered seperatly.
cool. read the full data sheet on on them on the site. sound pretty sweet. you know the price on these guys? i looked on crutchfield which is the only real authorized on line dealer they showed but i didnt even see them on there. gonna try ebay now unless you guys see an authorized dealer that has them online.
I was tempted to buy a pair on Ebay, where they retailed for $120/ pair. I have not seen them in a while, but I'm sure they are out there. I am still looking for other items to get my system going. I'll worry about them after I have the power supply upgraded.
I just pick up some Boston Acoustics Pro60 6.5 comps.The tweeters are connected to the mids.Should i leave them there or put them on my dash?I heard you should live them as close as possible to the mids.Any suggestions?[/quote/would in the sail panels adjacent to the outside rearviews be a good place to put the tweets or is that too far away from the mids in the door.
Just a reminder, no warranty no matter what anyone says unless it's from Crutchfield which is the only online authorized dealer. I know.
The imaging system does work well, though.//content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
wildboys
wildboys
memphis tn
00poop6x
