Speaker wire...need help choosing right gauge
  • 6
imloudek
ny/nj
Hey...got a 1500 watt rms set up for voice speakers...I have 14 gauge speaker wire...but I feel like I should go down to 12 or 10...as it will be carrying a lot of power...
Thoughts or advice?
These will be short runs of wire FYI...
Maybe 3-5 feet at most
Thoughts or advice?
Voice speakers?
What amp and speakers/tweeters are you running?
Google Search is your friend..
"Despite popular belief, this is not necessary for noise rejection. As long as the impedances are balanced, noise will couple equally into the two wires (and be rejected by a differential amplifier), regardless of the signal that is present on them."
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
902
So u know the individual slots on the ISO connectors and where they go? 12 volt red is accessories. etc. Red wire goes to the amplifier...
Ppl love their Cruze Often it’s increasing the turbo size, changing the suspension from stock being fe1-3 to fe5, sway bar and links then brakes...
imloudek
imloudek
ny/nj
negolien
    May 16, 2024
    May 16, 2024
