Speaker troubleshooting help
S13via
4
FL
hey everyone
91 accord
installed a pioneer headunit in my car weeks ago, blown OEM speakers, played sound thru each one.
new speakers came in other day, installed the rear two
turned on my headunit and there is no sound from the new rears and oem fronts, just an inital pop sound and then silence.
and I used butt connectors
appreciate the help, thanks
I sorta have the same issue. I just install a pioneer avh dvd 4000 in my f150 crew. I used a wire harness from crutchfield from the factory harness to the reciever harness. I also hooked up a DEI 528t to bypass the parking brake. I have the grounds ( black and yellow)from the 528t hooked to the grounds on the wire harnesses. I know my polarity is right. I am using the factory sub, amp and speakers with this setop. evertyime i turn on the car i get a popping sound from my speakers. also when i put in a dvd while the radio is allreayd on get the same noise. not sure why. Is the head unit to much power for factory componets? I do get dimming when i turn on the headlights. I have been searching threads but heck man there are so many threads to search i will be here for an eternity tis is the closest i could match. thanks
S13via
S13via
FL
drewskins
vegang
vegang
