speaker size for 70 chevelle
Sounds like the old system, with one speaker up front and one in back. If you want to have four all around, you'd better start thinking about where to cut. My friend's old '68 had speakers put into the doors and the rear deck and they were certainly not the stock locations. You'll have to customize it or pay someone else to do it for you. On the bright side, the '70 is a popular car, so finding someone familiar with it should be no problem at all. Good luck!
first off it's not my car (helping a friend out)
2nd speakers are in the dash
i found the only speaker sizes on a chevelle fan club site and they said it was a shallow mount in the dash for the 4x6. they said if they were too deep it could cause problames with dash cluster
this is the only place i found that said any info on speaker size
http://www.chevelles.com/forums/showthread.php?t=49048&highlight=speaker+sizes
and before we order any thing we want to make sure of the sizes
thanks
ben
I would try to find a good set of 4x6 plates for the front and either some decent 6x9s for rear (some will hit hard enough that your friend might not want a sub), or a single/dual 10/12" setup for rear. That car has a pretty big trunk so your options are flexible. Try to see if you can find out how deep of clearance you have up front.
millerscents
who knows what i am
millerscents
sapulpa, OK
SHOtime
michigan born
    May 14, 2026
michigan born
    May 14, 2026
