Speaker problems
Boomer14
I have an FI Audio 18 inch sub in my 93 mercury sable i have a 300 watt cerwin vega amp to the sub. When I turn the sub on from my stereo the sub starts to hit but as I turn up the volume the sub start to pulsate nonstop and i turn the sub off and it still pulsates on its own. I have checked the wires they are fine the fuses are fine. I was wondering if somone could help on figuring out why the sub is pulsating cause i cant even have it on any more with out it doing that?
It sounds like you have some nasty engine noise going into the sub amp. Is this pulsating audible? Do you get music sounds out of the sub? How is the amp wired? Are you using preamp outputs or a line output converter? Need some details to help you out.
I can get some bass to the speaker but when I turn the volume up on the stereo it the sub starts to continuosly pulsate nonstop and the wiring is just two wires coming from the speaker one goes in the positive and the other one in the negative and I turned the amp output to make the speaker hit harder and the amp is only 300 watts the only way to get the speaker to stop is to turn my car of completely and when the sub pulsates for like 1 min the middle part that says FI gets really hot.
Almost sounds like your amplifier PCB is dumping high voltage to the speakers. Sounds like it is AC voltage, which at least says the amp is sending out the right information, just too much.
If he is even close to right, your sub isn't going to last long. I would disconnect the sub from the amp and find a new amp. Honestly, you don't sound like you know what you're doing. I suggest finding a professional installer and having them take a look at your setup.
a big huge X's 2
Boomer14
Boomer14
Versailles, KY
MTX520
AJ (ACE)
    Jun 28, 2026
Mike Mccabe
    Jun 28, 2026
