Speaker noise
5thgenaccord
I have been trying to get rid of that **** sound for awhile now. I was wondering if I can run my remote wire with my rcas? The power wire is on the opposite side. I use to have a eclipse deck and I thought me and my car audio salesman came to the conclusion that it was the deck, but it isn't. I have a new pioneer deck and I still have the sound though my rear speakers. Sometime soon, I will replace the rca that runs back to that amp but I was wondering if you can run your rcas with your remote wire? And the amp is new a pbx 4 channel I had the problem also when I had a pioneer 2 channel. Also, do you think it could be a diode in the alternator?
The alt could be bad, but most likely you just have a bad ground in the system somewhere. Make sure that you have a clean metal on metal connection (no paint in the way) for your amp ground and try regrounding your head unit. The remote wire has nothing to do with it, and you CAN run your RCAs with your power wire without any trouble.
5thgenaccord
5thgenaccord
Green Bay, WI
wilzyx
