keep_hope_alive
Premium Member
Acoustics Engineer
I never use an ignition voltage source at the fuse box for remote turn on. while it works and turns the amp on/off, it does so independent of the head unit. if the HU is turned off, but the amp is on, you can get noises or pops that can damage speakers. it's generally not a good idea unless you add a toggle switch at the dash. then every time you turn the car on/off, you use the switch to turn the amp on last (after HU) and off first (before HU). it gets old fast. you can buy a turn-on delay to help the turn-on issue, but that doesn't help turn-off.
always remember - you never want your amp on when your HU is off (or switching on/off).
you can buy LOC's with an auto turn-on feature. David Navone Engineering is my highest recommendation. that is the only reason I see you should buy a LOC.
your amp has high level inputs built in - those will usually outperform an external LOC. External components are subject to noise and increase wiring hassle. you don't need a LOC, you just need a turn-on signal.
sometimes, you can get one from the factory head unit - usually if a factory amp was an option. sometimes one is provided in the radio but not in the harness, so you need to add a pin to the harness to get it. every vehicle is different and i haven't seen a good resource for checking this. a vehicle specific forum may have someone who has done this. i mod a Honda Accord forum for that purpose - Accord specific help. You can also use a DMM to measure voltage on the wires (having a wire color code for your vehicle helps narrow it down a bit). you'll want to check the empty pins for voltage as well.
This link may help:
http://www.installdr.com/installdocs/flm/PDF/356017.pdf
This link may help:
