Speaker impedance
  • 2
DLJ
Hola. I've got an intriguing wiring question involving speaker impedance (redundant, I know).
Okay, I have two audio channels. Seven speakers. One demux.
Two of which are wired together in series, wired into the demux in parallel.
Another two in the exact same set up, together in series, to the board in parallel.
I have two wired in series, then to the board in a bridged parallel (positive on one channel, negative on the other).
I then have one speaker bridged in parallel (positive one channel, negative other).
So, how do I go about measuring total impedance to each channel? Since.. You know, if you count the two speakers in series and bridged as one speaker, I have two speakers bridged, in which case I can't measure TOTAL impedance on one channel. So.. Uh.. Yeah, any ideas?
I don't have the individual speaker ohms handy, I can check them tonight.
Use a dmm to test the resistance once you get them
729
True but at those prices, nickel plated copper or brass would be a much better option for speakers, no point in using stainless steel at all...
24
336
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
227
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
759
DLJ
DLJ
Aurora, CO
05trailblazer
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
