speaker diam and box height ok to be the same?
GrnEydDvl
Registered User
Never built my own box before so this may be a silly question.
Is it OK for the overall diam of a sub and the height of a box to be the same?
For example, would it be a bad idea to try to put a sub with these requirements in this box?
overall diam = 14 in
bolt hole circle = 12.7 in
I know I would just be screwing the box into the outer walls as well as the front. I ask because this is the only plan I can find that I trust that works with my desired tuning and sub and I would hate to build it only to find out it was doomed from the start.
I'd make it so the baffel was outside all the other walls, rather than inside them...
if that makes sense?
if not, go think about it for a while //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
edit: like this...
rather than having the front of the box fit within the side and top, cos if its inside the top and bottom, when you cut out the sub hole, you'll be getting the front in half basically //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
the cutting list for the plans you posted has the baffel inside the top and bottom I do believe.
also, make sure that the subwoofer cutout is less than 12.5inches in your case...
GrnEydDvl
Registered User
GrnEydDvl
parts unknown
saywhat?
