Speaker Depth Issue
MCarbonaro
I've put (2) 5.25" JL C2-525 speakers in the front doors of my '95 Corolla, however the stock speakers were 4" speakers. In order to compensate the increased mounting depth, I put 2" spacer blocks between the speakers and mounting brackets. My problem is that there's about 1.5" of exposed speaker in the cabin of the car now. I currently have duct tape covering the opening to protect the speakers, but this is nowhere near an ideal solution. Here's a picture of the speaker on the driver side:
Any suggestions for a better solution?
Do a search for custom kick panels. If you took the time to make some kick panels, you could get better 6.5" comps you could put in. Not sure how much money you're willing to let go, but that would be the best option if they are already underperforming your rear speakers. An amp would help out as well once you upgrade the speakers. But poor performance might also be due to that install job.....lol
I have all JL:
5.25"
6"x9"
12" sub
700/5 amp
Already dropped $900 on it less than a month ago for all the equipment, not looking to replace any of the speakers, just looking to better encase them. But thanks for your advice.
You should be able to cut away metal, if necessary, to clear the basket with a 1/2" spacer. Metra says you have 2" of mounting depth with a 4" speaker, and the components you have should be 2-1/2" deep. If you haven't hacked up the door panel to the point of no return you can still make this look decent.
if it were me, i'd do the following:
make a MDF spacer that gives you the desired depth while providing a good mounting surface. the desired spacer depth can be achieved using layers of rings. the outer-most ring would include t-nuts for driver mounting.
increase the cutout size of the factory door panel to match the speaker grill.
use foam weatherstripping to create seals between the new spacer and the metal doors and between the speaker and the spacer.
paint/resin/coat the spacer to waterproof it.
bolt the spacer to the door, screw speaker to spacer.
my build logs has a similar process
if you want your investment to be worth it, plan on spending 4-6 hours or more fabricating new door speaker mounts/rings/seals.
...if you want your investment to be worth it, plan on spending 4-6 hours or more fabricating new door speaker mounts/rings/seals.
Good advice, but for anyone who jumped the gun by buying stuff that wouldn't fit, to begin with, and then spent all of 5 minutes "fixing" it with a roll of duct tape....
I was thinking something along the lines of encasing the speakers in 4.75" PVC pipe (if such a pipe/ comparable pipe exists; or some sort of thick/ long wood ring.) I wouldn't want to use a metal pipe because that would lead to sound distortion/modification. Where could I find these "spacer rings?"
you make them out of wood using a jig saw (and drill bit to make a starting hole). my build log has examples.
a large PVC pipe will still have a resonant frequency, and then mounting is tricky. you want a flat surface that can accept mounting screws on the speaker basket and then bolt to the door metal.
i'm glad he thought to seal it with anything. that shows effort, and he took the time to share the pic, admit it was not correct, and ask for the right way to do it.
i answer every post as if the asker wants to know the right way to do it. inform, then let them decide if they want to make sacrifices.
Very true, thanks for calling me on my earlier remark.
Everyone gots to learn, and something is better than nothing.....Guess my feelings got hurt just a bit seeing that poor JL surrounded by the ol' Duck Tape, lol
MCarbonaro
MCarbonaro
New York
Flex68
