Soundstream TRX 4.640 4 Channel BEAST CHEAP
jdubbau
Item(s) for Sale: Soundstream TRX 4.640
10/10 Functionality and 6.5,7/10 or so on cosmetic as it does have some damage to the fins as there is a bend in one and paint rubbed off as this is how I got it. Otherwise great amp that actually surprised me on the output. Uses 3 25amp fuses as well and I also noticed the endcaps did not come with this amp and never noticed until now.
  • 100 Watt x 4 Channel @ 4 Ohm
  • 160 Watt x 4 Channel @ 2 Ohm
  • 320 Watt x 2 Channel @ 1 Ohm
  • 640 Watt MAX
  • Class A/B
  • 4/3/2 Channel Operation
  • MOSFET Pulse Width Modulated Power Supply
  • IDI (Intelligent Distress Indicator)
  • LED Power, Protect
  • Gloss Black Finish w/ Gray End Caps
  • Three-Way Protection Circuitry (thermal, short, impedance)
  • Variable Crossovers (HPF/Full/LPF)
  • Variable Low/High pass filter (50-150 Hz)
  • Variable Bass Boost
  • Pre-Amp Outputs
  • Platinum RCA Level Inputs
  • Platinum 4 Gauge Power Connectors
  • Frequency Response: 10-3.5 kHz
  • Phase Shift: 0-180°
  • Direct 4 ga. Power & 8 ga. Speaker Terminals
  • Dimensions: 20"L x 11"W x 2-5/8"H
Price: $115 Shipped in Con US only
Mine connected just fine, but I liked the onboard menu better and deleted the app.
45
4K
Very true statement here. Can also possibly damage the subs if not used properly,and may even cook an amplifier in the process possibly. It may be...
Hello I have the soundstream bx 108z and just recently the remote wier came out of the power connector so I put it back in and then noticed that...
jdubbau
jdubbau
evansville In
mikelaubach
maylar
    Jun 2, 2024
    Jun 1, 2024
