Fs:mtx thunder 7804 & 8502
kill y-tee
Senior Baller
Item(s) for Sale: 1 MTX THUNDER 8502 2-channel Amp, 1 MTX THUNDER 7804 4-channel Amp
Both Amplifiers are used but are in %100 working order. Both amps have scuffs and scratches. Mostly wear from installation, 8502 has some plastic cracked off around speaker output terminals but does not affect speaker connection.
8502 specs:# 2-Channel Class A/B Amplifier
# Prizm EFX: Selectable Lighting Color, or Pusate to Beat
# Xtant Technologies Cooling: Thermal-Regulated, Turbo-Charged Intercooler
# RMS Minimum Power Rating:
* 125 Watts x 2 Channel @ 4 Ohms
* 250 Watts x 2 Channel @ 2 Ohms
* 375 Watts x 2 Channel @ 1 Ohm
* 500 Watts x 1 Channel @ 4 Ohms Bridged
* 750 Watts x 1 Channel @ 2 Ohms Bridged
# CEA-2006 Compliant
# ARC: Cut 0-15dB, Freq. 200Hz
# Power and Protection LEDs
# Parametric Bass Control:
* -12 - +12 dB Bass Control
* Variable Bass Control Frequency: 30 - 80 Hz
* Variable Bass Control Q: 0.5 - 4.0
# Onboard Crossover: HP ( 40 - 350 Hz), Sub (30 Hz)
# Semi Unregulated MOSFET Power Supply
# High or Low-level Input
# Adjustable Input Sensitivity: 100mV - 1V / 1V - 10V
# 4 Gauge Power Connectors with Built-In 8 Gauge Capacitor Terminals
# Frequency Response: 20 Hz - 20 kHz
# Dimensions: 20-11/16" L x 9-5/8" W x 2-1/2" H
7804 specs:# Thunder 4-channel Super Amplifier featuring patented class A/B output
# 100 watts RMS x 4 at 4 ohms, 200 watts x 4 at 2 ohms
# 400 watts RMS x 2 bridged output at 4 ohms, 800 watts x 1 front/rear summed output
# Xtant Technology Cooling (XTC) - Thermal-regulated turbo-charged fan intercooler
# PrizmEFX accent lighting effects - Customizable to match your vehicle's interior
# Semi-unregulated MOSFET power supply
# Overload and thermal protection
# StreetWires connection terminals
# Variable electronic crossover at 40~350 Hz, selectable 12 dB Hi/24 dB Low Mono, defeatable
# Bass boost at 40 Hz, 0~18 dB/octave variable
# A.R.C. (Active Resonance Control): Cut 0~15 dB/octave, Freq. 200 Hz
# Input (RCA connection): Low-level, hi-level w/Smart Engage
# Input sensitivity: 100mV-1V/1V-10V switchable
Price: I am asking $500.00 shipped for the pair. Lower 48 only. Price is firm.
kill y-tee
Senior Baller
kill y-tee
Montana
kill y-tee
