Item(s) for Sale: Soundstream TRX 4.640
10/10 Functionality and 6.5,7/10 or so on cosmetic as it does have some damage to the fins as there is a bend in one and paint rubbed off as this is how I got it. Otherwise great amp that actually surprised me on the output. Uses 3 25amp fuses as well and I also noticed the endcaps did not come with this amp and never noticed until now.
Price: $115 Shipped in Con US only
- 100 Watt x 4 Channel @ 4 Ohm
- 160 Watt x 4 Channel @ 2 Ohm
- 320 Watt x 2 Channel @ 1 Ohm
- 640 Watt MAX
- Class A/B
- 4/3/2 Channel Operation
- MOSFET Pulse Width Modulated Power Supply
- IDI (Intelligent Distress Indicator)
- LED Power, Protect
- Gloss Black Finish w/ Gray End Caps
- Three-Way Protection Circuitry (thermal, short, impedance)
- Variable Crossovers (HPF/Full/LPF)
- Variable Low/High pass filter (50-150 Hz)
- Variable Bass Boost
- Pre-Amp Outputs
- Platinum RCA Level Inputs
- Platinum 4 Gauge Power Connectors
- Frequency Response: 10-3.5 kHz
- Phase Shift: 0-180°
- Direct 4 ga. Power & 8 ga. Speaker Terminals
- Dimensions: 20"L x 11"W x 2-5/8"H
