Sound Stream taranchula amp???
can only do it if its going to be stable at 1 ohm... it might be able to support that low impedence. but if its not able to, then it might catch on fire :p
give it a shot and see if it goes into the protection circuit. it does have a protection circuit, right? i just ask because my amp didnt(notice the use of past tense here...)
oh yeah, and i believe the spelling is tarantula //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I believe he said 2 dvc 2oh msubs that would need a 2ohm load stable amp now Adire does say you need only 500 - 600 rms for a ported brahma in the correct box but I dunno. But that amp should do 2 ohm bridged I believe.
dude i have the same amp hooked up to two HPO 15's and its a good amp but it wont push 1600 to each sub just hook it up both speakers at 2ohm and you will be amazed as to how loud it will be and how clean it will sound thats your best bet because the amp can only take 4ohm, 2ohm, or 4ohm bridged. dont push it its expensive to replace
if each channel is only stable to 2 ohms, then bridged it would only be stable at 4 ohms
2 ohm DVC's cant be wired to 2 ohms... unless you just hook up one coil, and if you do that, good luck getting it to hold 1600w.
Bigrick31
Carpe Diem
Bigrick31
Mid*Cal
hoss
